[postgis-users] postgis_restore and user privileges
strk at refractions.net
Thu Sep 16 01:19:53 PDT 2004
As you noted for pg_restore it seems that -x prevents
that (ACL) in pg_dump too.
You should ask on the pgsql-users mailing list.
Also check -O (prevent owner set) for both apps.
A last tip: are you superuser when restoring ?
--strk;
On Thu, Sep 16, 2004 at 10:06:05AM +0200, Stefano Bonnin wrote:
> I have a doubt:
> is sure that "pg_dump -Fc" dumps the user privileges?
> if I try
> ./pg_restore -l mydump.sql
> I don't see anythink about privileges
> postgis-users mailing list
