[postgis-users] RE: [postgis-devel] GML output
Martin Daly
Martin.Daly at cadcorp.com
Thu Sep 23 06:05:19 PDT 2004
strk,
> If think output size is a concern.
Then don't use XML..., or gzip the output. XML parsers can typically
cope with gzip, or at least be modified to.
> Can't both namespace and srsName be written in a parent element ?
There are all sorts of ways to cope with namespaces, but for maximum
interoperability and transparency, I'd use gml: each time. Our
(Cadcorp's) GML exporter puts the srsName= on the gml:Point,
gml:LineString, gml:Polygon, and gml:Multi-s, not on any of their
members (from memory it is even allowed on gml:coordinates). That
seemed a reasonable compromise between just on the FeatureCollection,
and everywhere.
> Do you think postgis should 'flatten' nested collections
> or keep them as they are ?
Flattening is annoying for systems that support the complex types - the
other properties are duplicated, or are wrong if pre-calculated, e.g.
area, etc. - but unavoidable to support systems that only support simple
types. Not a choice I'm keen to make for you, I'm afraid. You might
also find systems that support a single geometry type per
FeatureCollection, like with shapefile, but I guess a WHERE clause could
take care of that.
Regards,
Martin
