[postgis-users] geocoder
Rich Gibson rich at testingrange.com
Tue Sep 28 13:43:50 PDT 2004
This is not a pl/sql answer, but Schuyler Erle has created
http://geocoder.us as a free geocder using Tiger data.  The Perl
source code is on CPAN, so you can download the code and data and run a
local instance.
On Tue, 28 Sep 2004, David Bitner wrote:
> Has anybody out there created a geocoder function in pl/sql for use with
> postgis?  I don't want to reinvent the wheel if anyone has done this, and if
> nobody has done this, I would love to get any pointers on how best to start.
> Completely within postgis I would like to be able to use a function like:
> select geocode("5555 Address Ave, Minneapolis, MN 55555") from streets_db
> or
> select * from geocode("...",streets_db)
> The return should be a temporary table with rows ranked by likelihood
> containing interpolated point location, the geometry of the line segment
> section, and the component parts of the address itself in a normalized form
> (av gets changed to ave).
> Using php and mapserver, I have implemented a ragtag geocoder, but I think
> that it would be a much cleaner and easier approach to do the address
> normalization and the scoring completely within pl/sql.  Problem is, I have
> no programming experience with pl/sql -- not to say that I'm not ready to
> get my hands dirty.
> Thanks,
> David
> postgis-users mailing list
