On Fri, Apr 01, 2005 at 02:27:50AM -0500, Akira Komo wrote: > Paul, > > The problem was solved by using the cvs version of postgis. It seems > rc6 doesn't work in thois case. > > Thank you again for your help. Have a nice day. There is NO change between rc6 and current CVS. Maybe you just needed a make clean ? --strk;
