[postgis-users] Loading data
Markus Schaber markus at schabi.de
Mon Apr 4 01:17:39 PDT 2005
Hi, Robert,
Robert Aldridge schrieb:
> Thanks to both Dylan and Brent.
> I got past my initial problems and got the SQL to run,
> but then realized a boneheaded mistake I'd made when
> pgsql reported:
> ERROR:  could not create unique index
> DETAIL:  Table contains duplicated values.
> When I combined the two SQL files, I didn't adjust the
> GID values (both files started at '0').  So, once I
> fix that, I should have a new 'roads' layer in
> PostGIS.
did you try the "-a" option of shp2pgsql for the second of your files?
this should avoid the GID collission.
Markus
