[postgis-users] Installing postgis
Achim Weßling
achim.wessling at gt-net.de
Fri Apr 15 03:28:08 PDT 2005
Hallo,
I'm just on the way installing postgis 1.0.0 rc6. I followed the
installationinstructions in the pdf-document provided at
http://postgis.refractions.net/docs/postgis.pdf.
Here in chapter 2.2 is said:
Once your PostgreSQL installation is up-to-date, enter the "postgis"
directory, and edit the Makefile.
But Makefile says I've to use Makefile.config.
So wouldn't you better change the above statement to:
directory, and edit the Makefile.config.
Achim
