[postgis-users] Installing postgis
strk at refractions.net
Fri Apr 15 13:08:41 PDT 2005
Thanks for pointing out, fixed.
--strk;
On Fri, Apr 15, 2005 at 12:28:08PM +0200, Achim Weßling wrote:
> Hallo,
> I'm just on the way installing postgis 1.0.0 rc6. I followed the
> installationinstructions in the pdf-document provided at
> http://postgis.refractions.net/docs/postgis.pdf.
> Here in chapter 2.2 is said:
> Once your PostgreSQL installation is up-to-date, enter the "postgis"
> directory, and edit the Makefile.
> But Makefile says I've to use Makefile.config.
> So wouldn't you better change the above statement to:
> directory, and edit the Makefile.config.
> Achim
> postgis-users mailing list
