[postgis-users] Early Special: 1.0.0 Released
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 20 10:49:09 PDT 2005
Awesome job guys!
I have a question on upgrading because I have never done that before.
I'm on FreeBSD and use the portsupgrade utility so it just pretty much
happens. The problem with this is I don't have access to an of the new
info until after the upgrade (I should browse CVS I guess).
My question is do I need to do the dump before the upgrade? or is the
dump utility smart enough to dump the old format also. And if so, what
is the command I should use to do the dump the tables?
Thanks,
-Steve W.
Paul Ramsey wrote:
> Just for you list'ers an early announcement of 1.0.0:
> After a long series of release candidates, the much anticipated 1.0.0
> version of PostGIS has been released. The 1.0.0 version includes
> substantial changes over the original 0.X series, most importantly a new
> on-disk format which is both more compact and faster to access. The
> 1.0.0 version is compatible with PostgreSQL 7.2 and higher, but is most
> tighhtly integrated with the PostgreSQL 8.0 and higher releases.
> New features in 1.0.0 include:
> * Smaller and faster on-disk formats
> * Improved selectivity estimates, including support for join
> selectivity and sub-selects
> * Hex-based canonical format, for driftless dump and restore
> * 4-D geometries
> * New functions:
> o Polygonize
> o AsGML
> o ForceRHR
> o SnapToGrid
> o Geometry Constructors
> * Improved JDBC interface with jdbc2 support
> * 64-bit platform support
> * Performance improvements for common boolean operators
> Current users of PostGIS will want to read the README file on upgrading
> with particular attention to the use of the utils/postgis_restore.pl
> script.
> postgis-users mailing list
