[postgis-users] Early Special: 1.0.0 Released
Eduardo Patto Kanegae
lists at webmapit.com.br
Wed Apr 20 12:22:41 PDT 2005
Hi folks,
Congratulations for the great job!
Is the $postgis/doc/postgis.xml file updated with PostGIS 1.0.0 too?
best.
http://www.webmapit.com.br
Skype: eduardopattokanegae
MSN: eduardo_patto~at~hotmail.com
ICQ: 303747254
Phone: +55(16)9994-2928
strk at refractions.net wrote:
>On Wed, Apr 20, 2005 at 01:49:09PM -0400, Stephen Woodbridge wrote:
>>Awesome job guys!
>>I have a question on upgrading because I have never done that before.
>>I'm on FreeBSD and use the portsupgrade utility so it just pretty much
>>happens. The problem with this is I don't have access to an of the new
>>info until after the upgrade (I should browse CVS I guess).
>>My question is do I need to do the dump before the upgrade? or is the
>>dump utility smart enough to dump the old format also. And if so, what
>>is the command I should use to do the dump the tables?
>The online manual show be clear enough, and fixed if is not.
>http://postgis.refractions.net/docs/ch02.html#upgrading
>Actually.. there's probably an important note missing, which
>is that the dump phase (first step) must be done *before*
>the new postgis is installed.
>The 'make install' command must be given after the dump has
>been produced and *before* the postgis_restore.pl script
>is invoked. Running postgis_restore.pl *before* the new
>postgis library is installed might result in unresolved
>references but since you have the dump you can restore
>again after installing the new one.
>VERY IMPORTANT: make your dumps BEFORE installing the
>new postgis !
>--strk;
>>Thanks,
>> -Steve W.
>>Paul Ramsey wrote:
>>>Just for you list'ers an early announcement of 1.0.0:
>>>After a long series of release candidates, the much anticipated 1.0.0
>>>version of PostGIS has been released. The 1.0.0 version includes
>>>substantial changes over the original 0.X series, most importantly a new
>>>on-disk format which is both more compact and faster to access. The
>>>1.0.0 version is compatible with PostgreSQL 7.2 and higher, but is most
>>>tighhtly integrated with the PostgreSQL 8.0 and higher releases.
>>>New features in 1.0.0 include:
>>> * Smaller and faster on-disk formats
>>> * Improved selectivity estimates, including support for join
>>>selectivity and sub-selects
>>> * Hex-based canonical format, for driftless dump and restore
>>> * 4-D geometries
>>> * New functions:
>>> o Polygonize
>>> o AsGML
>>> o ForceRHR
>>> o SnapToGrid
>>> o Geometry Constructors
>>> * Improved JDBC interface with jdbc2 support
>>> * 64-bit platform support
>>> * Performance improvements for common boolean operators
>>>Current users of PostGIS will want to read the README file on upgrading
>>>with particular attention to the use of the utils/postgis_restore.pl
>>>script.
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
