[postgis-users] problem with lwpostgis.sql
strk at refractions.net
Thu Apr 21 01:55:38 PDT 2005
The interesting part of the error is the initial one, the first ERROR
is meaningful, the other just says an error occurred before and thus
every command is ignored.
--strk;
On Thu, Apr 21, 2005 at 02:54:20PM +0800, ?? wrote:
> Hi!
> when install postgis 1.0.0,
> $createlang plpgsql test (ok,test is mydatabase)
> $psql -f lwpostgis.sql -d test (this is not ok)
> part of error message:
> -------------------------------error message-----------------------------
> ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3008: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3013: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3018: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3024: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3029: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3034: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3039: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3044: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3052: ERROR: current transaction is aborted, commands ignored until end of transac
> tion block
> psql:lwpostgis.sql:3057: ERROR: current transaction is aborted, commands ignored until end of transac tion block
> psql:lwpostgis.sql:3062: ERROR: current transaction is aborted, commands ignored until end of transac tion block
> psql:lwpostgis.sql:3071: ERROR: current transaction is aborted, commands ignored until end of transac tion block
> psql:lwpostgis.sql:3077: ERROR: current transaction is aborted, commands ignored until end of transac tion block
> psql:lwpostgis.sql:3083: ERROR: current transaction is aborted, commands ignored until end of transac tion block
> ROLLBACK
> whereis wrong ?How do? Please help me,thanks very much!
> The following is how i install postgis :
> tar zxvf postgis-1.0.0.tar.gz
> copy postgis-1.0.0 to path/postgresql-8.0.1/contrib
> cd path /postgresql-8.0.1/contrib (the following operation all in this DIR)
> #LDFLAGS=-lstdc++ ./configure --enable-autoconf --with-geos=
> postgis-users mailing list
