[postgis-users] problem with lwpostgis.sql
Markus Schaber
schabi at logix-tt.com
Thu Apr 21 03:18:24 PDT 2005
Hi, Strk and ??,
strk at refractions.net schrieb:
> The interesting part of the error is the initial one, the first ERROR
> is meaningful, the other just says an error occurred before and thus
> every command is ignored.
>>$psql -f lwpostgis.sql -d test (this is not ok)
To help debgging, you may use the -s option:
psql -s -f lwpostgis.sql -d test
HTH,
Markus
