[postgis-users] postgis-cvs link error on mingw
Jean David TECHER davidtecher at yahoo.fr
Thu Apr 21 08:18:52 PDT 2005
Hi Sandro
Ok..;I'll download PG 8.0.2 and do the test :-) for
Geos 2.1.1
proj 4.4.9
PG 8.0.2
PostGIS 1.0.0
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Thursday, April 21, 2005 5:08 PM
Subject: Re: [postgis-users] postgis-cvs link error on mingw
> Are you referring to the HEAD branch ?
> If you do did you run ./configure ? [ yes, for HEAD tests that's the
way! ]
> The HEAD branch contains code trying to do w/out postgresql build
> scripts, which are probably much smarter about cross-platform issues.
> David can probably help more then me here as I don't have a win32 system
> to check this out. It would be good checking command line differences
> between 1.0 and HEAD branch on a win32 system.
> --strk;
> On Thu, Apr 21, 2005 at 11:46:54AM -0300, Adão Paulino wrote:
> > Hi,
> > I'm trying to build PostGIS 1.0.0 on PostGres 8.0.2, using  Windows and
MingW.
> > I've used the instructions from TECHER Jean David and no errors has
occured until I try to run 'Make' on '/home/src/postgres-8.0.2/contrib',
after setting USE_PROJ and USE_GEOS to 1,  PROJ_DIR = 1 and GEOS_DIR = 1 int
the Makefile.Config.
> > I've got the following after the make command:
> > Administrador at HP6 /home/src/postgresql-8.0.2/contrib/postgis-1.0.0
> > $ make
> > make -C lwgeom
> > make[1]: Entering directory
`/home/src/postgresql-8.0.2/contrib/postgis-1.0.0/lwgeom'
> > sh ../geos_version.sh /c/postgres-8.0.2 > postgis_geos_version.h
> > dlltool --export-all  --output-def lwgeom.def measures.o box2d.o
ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o
lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o  wktunparse.o
lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o
lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o
lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o
lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
lwgeom_triggers.o lwgeom_dump.o
> > dllwrap  -o liblwgeom.dll --dllname liblwgeom.dll  --def lwgeom.def
measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o
lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o
wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o
lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o
lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o
lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o
stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o
lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o
lwgeom_dump.o -L/home/src/postgresql-8.0.2/contrib/postgis-1.0.0/../../src/p
ort -L/home/src/postgresql-8.0.2/contrib/postgis-1.0.0/../../src/port  -lstd
c++ -L/c/postgres-8.0.2/lib -lgeos -L/c/postgres-8.0.2/lib -lproj -L/home/sr
c/postgresql-8.0.2/contrib/postgis-1.0.0/../../src/backend -lpostgres
c:\MingW\bin\..\lib\gcc-lib\mingw32\3.2.3\..\..\..\..\mingw32\bin\ld.exe:
cannot find -lpostgres
> > c:\MingW\bin\dllwrap.exe: c:\MingW\bin\gcc exited with status 1
> > make[1]: *** [liblwgeom.dll] Error 1
> > make[1]: Leaving directory
> > make: *** [liblwgeom] Error 2
> > Could someone help me?
> > Thanks in advance.
> > Adão Paulino.
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
