[postgis-users] postgis-cvs link error on mingw
strk at refractions.net
Thu Apr 21 08:23:09 PDT 2005
You can do the test with the PG version you already
have, it's a linking commandline problem.
Its enough to know if PostGIS HEAD branch (I think the snapshot
online is from HEAD) works with win32.
--strk;
On Thu, Apr 21, 2005 at 05:18:52PM +0200, Jean David TECHER wrote:
> Hi Sandro
> Ok..;I'll download PG 8.0.2 and do the test :-) for
> Geos 2.1.1
> proj 4.4.9
> PG 8.0.2
> PostGIS 1.0.0
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
> ----- Original Message -----
> From: <strk at refractions.net>
> To: <postgis-users at postgis.refractions.net>
> Sent: Thursday, April 21, 2005 5:08 PM
> Subject: Re: [postgis-users] postgis-cvs link error on mingw
> > Are you referring to the HEAD branch ?
> > If you do did you run ./configure ? [ yes, for HEAD tests that's the
> way! ]
> > The HEAD branch contains code trying to do w/out postgresql build
> > scripts, which are probably much smarter about cross-platform issues.
> > David can probably help more then me here as I don't have a win32 system
> > to check this out. It would be good checking command line differences
> > between 1.0 and HEAD branch on a win32 system.
> > --strk;
> > On Thu, Apr 21, 2005 at 11:46:54AM -0300, Adão Paulino wrote:
> > > Hi,
> > > I'm trying to build PostGIS 1.0.0 on PostGres 8.0.2, using Windows and
> MingW.
> > > I've used the instructions from TECHER Jean David and no errors has
> occured until I try to run 'Make' on '/home/src/postgres-8.0.2/contrib',
> after setting USE_PROJ and USE_GEOS to 1, PROJ_DIR = 1 and GEOS_DIR = 1 int
> the Makefile.Config.
> > > I've got the following after the make command:
> > > Administrador at HP6 /home/src/postgresql-8.0.2/contrib/postgis-1.0.0
> > > $ make
> > > make -C lwgeom
> > > make[1]: Entering directory
> `/home/src/postgresql-8.0.2/contrib/postgis-1.0.0/lwgeom'
> > > sh ../geos_version.sh /c/postgres-8.0.2 > postgis_geos_version.h
> > > dlltool --export-all --output-def lwgeom.def measures.o box2d.o
> ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o
> lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o wktunparse.o
> lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o
> lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
> lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o
> lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o
> lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
> lwgeom_triggers.o lwgeom_dump.o
> > > dllwrap -o liblwgeom.dll --dllname liblwgeom.dll --def lwgeom.def
> measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o
> lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o
> wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o
> lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o
> lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o
> lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o
> stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o
> lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o
> lwgeom_dump.o -L/home/src/postgresql-8.0.2/contrib/postgis-1.0.0/../../src/p
> ort -L/home/src/postgresql-8.0.2/contrib/postgis-1.0.0/../../src/port -lstd
> c++ -L/c/postgres-8.0.2/lib -lgeos -L/c/postgres-8.0.2/lib -lproj -L/home/sr
> c/postgresql-8.0.2/contrib/postgis-1.0.0/../../src/backend -lpostgres
> c:\MingW\bin\..\lib\gcc-lib\mingw32\3.2.3\..\..\..\..\mingw32\bin\ld.exe:
> cannot find -lpostgres
> > > c:\MingW\bin\dllwrap.exe: c:\MingW\bin\gcc exited with status 1
> > > make[1]: *** [liblwgeom.dll] Error 1
> > > make[1]: Leaving directory
> > > make: *** [liblwgeom] Error 2
> > > Could someone help me?
> > > Thanks in advance.
> > > Adão Paulino.
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
