[postgis-users] Compile CVS in MinGW
Jean David TECHER
davidtecher at yahoo.fr
Thu Apr 21 11:57:49 PDT 2005
I have problem too with cvs :-(
can' t find pwd.h, netdb.h inet.h.... in C:\postgreSQL \8.0.2\include\postgresql
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: PostGIS Users Discussion
Sent: Thursday, April 21, 2005 8:37 PM
Subject: [postgis-users] Compile CVS in MinGW
List,
I just compiled 1.0.0 in MinGW using Jean David's instructions...and it
wend without a hitch.
However, the same cannot be said for the CVS - I actually tried the CVS
first, but when I tried to configure it, it was unable to detect the
PostgreSQL source.
The following command from the PostGIS cvs source:
configure --enable-autoconf --with-geos=/c/PostgreSQL/8.0.2/bin/geos-config \
--with-proj=/c/PostgreSQL/8.0.2 \
--with-pgsql-src=/home/$USERNAME/sources/PostgreSQL/postgresql-8.0.2 --prefix=/c/PostgreSQL/8.0.2
returns:
checking for gcc...gcc
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for pg_config... no
configure: error: PostgreSQL is required by PostGIS
Any guesses as to what's going on? Should I just avoid the CVS for now?
Mike
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050421/31717327/attachment.html>
