[postgis-users] Compile CVS in MinGW
strk at refractions.net strk at refractions.net
Thu Apr 21 17:47:40 PDT 2005
On Thu, Apr 21, 2005 at 08:57:49PM +0200, Jean David TECHER wrote:
> I have problem too with cvs :-(
> can' t find pwd.h, netdb.h inet.h.... in C:\postgreSQL \8.0.2\include\postgresql
Which files are trying to include them ?
Can you show us more ?
--strk;
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
>   ----- Original Message -----
>   From: Mike Leahy
>   To: PostGIS Users Discussion
>   Sent: Thursday, April 21, 2005 8:37 PM
>   Subject: [postgis-users] Compile CVS in MinGW
> List,
> I just compiled 1.0.0 in MinGW using Jean David's instructions...and it
> wend without a hitch.
> However, the same cannot be said for the CVS - I actually tried the CVS
> first, but when I tried to configure it, it was unable to detect the
> PostgreSQL source.
> The following command from the PostGIS cvs source:
> configure --enable-autoconf --with-geos=/c/PostgreSQL/8.0.2/bin/geos-config \
> --with-proj=/c/PostgreSQL/8.0.2 \
> --with-pgsql-src=/home/$USERNAME/sources/PostgreSQL/postgresql-8.0.2 --prefix=/c/PostgreSQL/8.0.2
> returns:
> checking for gcc...gcc
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables... .exe
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for pg_config... no
> configure: error: PostgreSQL is required by PostGIS
> Any guesses as to what's going on?  Should I just avoid the CVS for now?
> Mike
>   _______________________________________________
>   postgis-users mailing list
>   postgis-users at postgis.refractions.net
>   http://postgis.refractions.net/mailman/listinfo/postgis-users
