[postgis-users] QGIS does not work with PostGIS 1.0
Tyler Mitchell
tylermitchell at shaw.ca
Fri Apr 29 21:32:10 PDT 2005
Niccolo,
You can revert to pre 1.0 version of PostGIS or wait for the next release of QGIS. The QGIS group might be able to give you more particulars about why it fails, but I believe the problem is with the new leight-weight geometries (lwgeom) introduced in PostGIS 1.0.
Does anyone else know if Niccolo could use the 'old' full geometries in a PostGIS 1.0 database? That would solve his problem for the meantime perhaps?
Tyler
----- Original Message -----
Date: Friday, April 29, 2005 2:44 pm
Subject: [postgis-users] QGIS does not work with PostGIS 1.0
> I cannot use QGIS 0.6 anymore after I installed the new PostGIS
> 1.0. The
> symptoms are those reported into the QGIS forum: blank screen upon
> loadingthe layer, crash on changing layer properties in dialogbox.
> Here the relevant thread:
> http://community.qgis.org/index.php?option=com_simpleboard&Itemid=41&func=vie
> w&id=24&catid=3
> > This has been confirmed. QGIS does not support PostGIS 1.0.x.
> > This is due to the change to the lightweight geometry objects.
> > For now, you must use PostGIS 0.9.x with QGIS.
> > We will address this issue in the upcoming release.
> > -gary
> Is there anything I can do to help solving the problem?
> Niccolo Rigacci
> Firenze - Italy
> War against Iraq? Not in my name!
> postgis-users mailing list
