[postgis-users] 3d Points
Christian Heine
christian at geosci.usyd.edu.au
Mon Aug 1 02:47:38 PDT 2005
Hi list,
a newbie needs some advice:
I want to store min/max z values and their associated lon/lat
obtained from regional grids in a postgis db. The values are spit out
as zmax/zmin (in km, mW/m^2, etc), zmax/zmin_lon, zmax/zmin_lat. As
far as I understand, one has to use GeomFromEWKT here as OpenGIS
formats only support 2d objects.
Is it advisable to use EWKT or is it better to create an extra z-
value column and keep the z-value separated from the lon/lat? Also,
what is the difference between POINTM and POINT? I couldn't find any
information explaining the "M".
Thanks a lot for the help.
Cheers from Sydney,
Christian
Christian Heine
ph.d. student
USIMS | University of Sydney
| Institute of Marine Science
| Sydney, Australia
P +61 2 9351 4257 • F +61 2 9351 0184
