[postgis-users] prepare_database(): Query error. Error executing
Nicolas Ribot
nicky666 at gmail.com
Tue Aug 2 02:24:01 PDT 2005
Hi Joe
Did not encounter this exact error message before, but you should try
to execute the offending query in postgis:
SELECT asbinary(force_collection(force_2d(geom)),'NDR'),gid::text
from province2000_proj
WHERE geom && setSRID('BOX3D(92.71
(by the way, the end of the query is missing).
If this query generates an error, it will be easier to fix.
When the query is working in postgis, adapt your mapfile to match the
modifications you made.
Nicolas
On 8/2/05, Jon Saints <saintsjd at yahoo.com> wrote:
> When attempting to connect to postgis from mapserver I
> get the error...
> msDrawMap(): Image handling error. Failed to draw
> layer named 'province2000_proj'.
> POSTGIS DECLARE (the actual query) statement: 'DECLARE
> mycursor BINARY CURSOR FOR SELECT
> from province2000_proj WHERE geom &&
> has anyone encountered this before?
> Thanks
> postgis-users mailing list
