[postgis-users] Simple question: How to get projected distance?
Lance Arlaus
lance.nospam.1 at codeberet.com
Wed Aug 10 08:03:59 PDT 2005
I know this is a simple question, but I'm just getting started with PostGIS
and I can't seem to perform a simple calculation.
I just need to calculate the distance between two points. What am I doing
wrong?
Query:
SELECT distance(PointFromText('POINT(40.8117 -74.218)', 32617),
PointFromText('POINT(40.8272 -74.1242)', 32617))
Returns:
0.095.
Of course if I do the following, I get a reasonable answer (about 10km), but
it's not exactly what I want
SELECT distance_sphere(PointFromText('POINT(40.8117 -74.218)', 32617),
Even constructing a line and taking the length doesn't work and I've tried
all SRIDs.
Sorry to ask such a simple question.
Also, is there a document that describes the well known SRIDs? I'm not sure
which one to use. For example, the data I've got references WGS 84, but
there's a ton of SRIDs defined. I've found docs describing the format of
the specification, but how are the SRIDs created (who serves as the
clearinghouse for this info)?
Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050810/b3724fe6/attachment.html>
