[postgis-users] Simple question: How to get projected distance?
Mike Leahy
mgleahy at fes.uwaterloo.ca
Wed Aug 10 09:34:07 PDT 2005
Correction...that url was misspelled - it's supposed to be
http://www.epsg.org - sorry.
Mike Leahy wrote:
> Hey there,
> I usually use transform() to convert my data to a UTM projection, so
> that I can calculate distances in metres with relative ease - maybe
> there's a more accurate way, but this works well enough for me.
> As for looking up SRID numbers, someone (either in this list or
> another) directed me to http://www.espg.org, where you can download a
> database of EPSG projection information, including a version in
> Microsoft Access format with forms for browsing. I believe the EPSG
> identifier is usually the same as the SRID in the spatial_ref_sys
> table included with PostGIS (but you'll want to compare the records
> for whatever projection you need to make sure I'm right about that).
> Regards,
> Mike
> Lance Arlaus wrote:
>> I know this is a simple question, but I’m just getting started with
>> PostGIS and I can’t seem to perform a simple calculation.
>> I just need to calculate the distance between two points. What am I
>> doing wrong?
>> Query:
>> SELECT distance(PointFromText('POINT(40.8117 -74.218)', 32617),
>> PointFromText('POINT(40.8272 -74.1242)', 32617))
>> Returns:
>> 0.095…
>> Of course if I do the following, I get a reasonable answer (about
>> 10km), but it’s not exactly what I want
>> SELECT distance_sphere(PointFromText('POINT(40.8117 -74.218)',
>> 32617), PointFromText('POINT(40.8272 -74.1242)', 32617))
>> Even constructing a line and taking the length doesn’t work and I’ve
>> tried all SRIDs.
>> Sorry to ask such a simple question.
>> Also, is there a document that describes the well known SRIDs? I’m
>> not sure which one to use. For example, the data I’ve got references
>> WGS 84, but there’s a ton of SRIDs defined. I’ve found docs
>> describing the format of the specification, but how are the SRIDs
>> created (who serves as the clearinghouse for this info)?
>> Thanks.
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050810/00af5a83/attachment.html>
