[postgis-users] Points within range of line
David Bitner
osgis.lists at gmail.com
Thu Aug 11 14:13:09 PDT 2005
select intersection(points,buffer(line,distance))
where points is the points geometry
line is your line geometry
and distance is the size of your buffer
On 8/11/05, Adrian Holovaty <postgis at holovaty.com> wrote:
> Given a PostGIS-enabled table of points, what's the best way to retrieve all
> the points that are within a certain distance of a given line? The line can
> have an arbitrary number of points (i.e., it's not straight).
> Surely this is a solved problem. Thanks for any help -- I'm still
> learning! :-)
> Adrian
> postgis-users mailing list
