[postgis-users] Cannot compile postgis on Fedora Core 4
M. Fioretti
mfioretti at mclink.it
Mon Aug 15 12:29:20 PDT 2005
Greetings,
I have a Fedora Core 4 system with PostgreSQL installed via rpm:
# rpm -q postgresql
postgresql-8.0.3-1
I have dowloaded postgis from the website. To follow the build
instructions (cd in "contrib" of postgresql source tree etc..)
I have also installed the postgresql source rpm for fedora core 4, and
then executed the postgis instruction from the contrib directory that
is created. However, the build still fails:
I have set PGSQL_SRC to
/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3
in Makefile.config
and I get:
[marco at polaris postgis-1.0.3]$ pwd
/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3/contrib/postgis-1.0.3
You have mail in /var/spool/mail/marco
[marco at polaris postgis-1.0.3]$ make
make -C lwgeom
make[1]: Entering directory
`/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3/contrib/postgis-1.0.3/lwgeom'
../Makefile.config:98:
/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3/src/Makefile.global:
No such file or directory
Makefile:113: /src/Makefile.shlib: No such file or directory
make[1]: *** No rule to make target `/src/Makefile.shlib'. Stop.
make[1]: Leaving directory
make: *** [liblwgeom] Error 2
I *have* seen in the postgis archive a similar message to this one,
but it doesn't seem to be the same problem I have. Any pointer?
TIA,
Marco
Marco Fioretti mfioretti, at the server mclink.it
Fedora Core 3 for low memory http://www.rule-project.org/
...the surest sign that intelligent life exists elsewhere in the
Universe is that none of it has tried to contact us. (Calvin)
