[postgis-users] Cannot compile postgis on Fedora Core 4
Jaime Carrera jaicarrerahdez at yahoo.com
Mon Aug 15 13:15:30 PDT 2005
I had the same problem and solved it by installing
postgresql FROM source (i.e. compiling it).
I had this problem in Red Hat 9 and when I upgraded to
fedora, decided to compile postgres from source
instead of downloading the rpms.
HTH
Jaime
 --- "M. Fioretti" <mfioretti at mclink.it> escribió:
> On Mon, Aug 15, 2005 13:33:11 PM -0600, Ethan Alpert
> (ealpert at digitalglobe.com) wrote:
> > You need to compile postgresql from source to
> build the postgis
> > extensions because postgis uses files in the
> source tree.
> This is why I installed the source RPM, as described
> in the original
> message. A source RPM *is* a copy of the whole
> source tree of the
> original package, plus all the patches needed for
> that distribution.
> Isn't it enough?
> > Look for a postgresql-dev perhaps if it exists you
> may be able to use
> > it.
> See above. I thought that the source RPM was all
> that I needed, and in
> fact when you "install" it it creates a src/contrib
> subdirectory. See
> the paths I mentioned in the original message.
> Or maybe I am completely missing something else?
> > -e
> > -----Original Message-----
> > From:
> postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]
> On Behalf Of M.
> > Fioretti
> > Sent: Monday, August 15, 2005 1:29 PM
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Cannot compile postgis on
> Fedora Core 4
> > Greetings,
> > I have a Fedora Core 4 system with PostgreSQL
> installed via rpm:
> > # rpm -q postgresql
> > postgresql-8.0.3-1
> > I have dowloaded postgis from the website. To
> follow the build
> > instructions (cd in "contrib" of postgresql source
> tree etc..) I have
> > also installed the postgresql source rpm for
> fedora core 4, and then
> > executed the postgis instruction from the contrib
> directory that is
> > created. However, the build still fails:
> > I have set PGSQL_SRC to
/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3
> > in Makefile.config
> > and I get:
> > [marco at polaris postgis-1.0.3]$ pwd
/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3/contri
> > b/postgis-1.0.3
> > You have mail in /var/spool/mail/marco
> > [marco at polaris postgis-1.0.3]$ make
> > make -C lwgeom
> > make[1]: Entering directory
`/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3/contr
> > ib/postgis-1.0.3/lwgeom'
> > ../Makefile.config:98:
/home/marco/RPM_FOUNDRY/SOURCES/postgresql-8.0.3/postgresql-8.0.3/src/Ma
> > kefile.global:
> > No such file or directory
> > Makefile:113: /src/Makefile.shlib: No such file or
> directory
> > make[1]: *** No rule to make target
> `/src/Makefile.shlib'.  Stop.
> > make[1]: Leaving directory
> > make: *** [liblwgeom] Error 2
> > I *have* seen in the postgis archive a similar
> message to this one, but
> > it doesn't seem to be the same problem I have. Any
> pointer?
> > TIA,
> > 	Marco
> Marco Fioretti                    mfioretti, at the
> server mclink.it
> Fedora Core 3 for low memory
> http://www.rule-project.org/
> "The SUN TROPIC beauty farm reopens today: featuring
> exotic swimming
>  pools, and, under the palm trees, **UVA lamps**"
> (unluckily for humankind, a REAL ad that I read in a
> real magazine)
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
