[postgis-users] Buffer bug ?
Daniel daniel.faivre at camptocamp.com
Fri Aug 26 06:06:38 PDT 2005
As said in my last post, the problem come from the buffer() function.
(the collect() only take 345 ms)
I will try a geos update this afternoon and post the result here.
Sincerely yours,
dF
Mark Cave-Ayland wrote:
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>Behalf Of Daniel
>>Sent: 26 August 2005 13:13
>>To: Mark Cave-Ayland (External)
>>Cc: Arnaud Saint Léger; 'PostGIS Users Discussion'
>>Subject: Re: [postgis-users] Buffer bug ?
>>Hi,
>>Thank u very much for your help. Here are precisions u requested:
>(cut)
>>6) splitting of the request:
>>6.1) CREATE TABLE temp_lg_annee_bis AS SELECT * FROM
>>lg_annee_bis WHERE lga_annee=2004 and lga_nat_cdn=2 and
>>lga_var > -1; ---> 345 milliseconds
>>6.2) buffer computing: the bug occur
>Hi Daniel,
>Well it doesn't look as if it's a database tuning problem. Can you try and
>isolate the whether it is the buffer() or the collect() which is taking the
>time by trying your query without the buffer(), e.g.
>	BEGIN;
>	CREATE TABLE temp_lg_annee_bis AS SELECT * FROM lg_annee_bis WHERE
>lga_annee=2004 and lga_nat_cdn=2 and lga_var > -1;
>	SELECT collect(lga_geom) FROM temp_lg_annee_bis GROUP BY lga_annee;
>	ABORT;
>If it is the buffer() which is causing the slowdown then it's definitely
>worth trying upgrading to the latest GEOS release which is now 2.1.4.
>Kind regards,
>Mark.
>WebBased Ltd
>17 Research Way
>Tamar Science Park
>Plymouth
>PL6 8BT
>T: +44 (0)1752 797131
>F: +44 (0)1752 791023
>W: http://www.webbased.co.uk
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050826/3fc82901/attachment.vcf>
