[postgis-users] MapServer subquery problem
Geodata Analysis
info at e-geodata.gr
Mon Aug 29 03:50:29 PDT 2005
Hi List,
I'm trying to add a layer from postgis in my mapfile but i get the
following error :
*Warning*: [MapServer Error]: prepare_database(): Error executing
POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY
CURSOR FOR SELECT asbinary(force_collection(force_2d(the_geom
from(SELECT table1.the_geom AS the_geom)),'NDR'),gid::text from table1,
table2 WHERE distance(table1.the_geom, table2.the_geom) < 1000) as foo
WHERE the_geom from(SELECT table1.the_geom AS the_geom &&
setSRID('BOX3D(742438.212 4108421.689,759685.98 4121357.515)'::BOX3D, -1 )'
Postgresql reports the error as 'ERROR: syntax error at or near "from"
at character 87 '
the line in my mapfile is :
DATA "the_geom from(SELECT table1.the_geom AS the_geom FROM
table1, table2 WHERE distance(table1.the_geom, table2.the_geom) < 1000)
as foo using unique gid using srid=-1"
1. I've tried a lot variations
2. If I declare the layer without the subquery, all the data is
displayed correctly.
3. If I execute the query : select the_geom from(SELECT table1.the_geom
AS the_geom FROM table1, table2 WHERE distance(table1.the_geom,
table2.the_geom) < 1000) as foo in phppgadmin, I get the correct results
Any ideas ?
Thank you
Stathis Stergou
Gis Programmer
