[postgis-users] ERROR: bogus varno: 1 with 8.1beta and postgis 1.0.3 (fwd)
rm_postgis at cheapcomplexdevices.com rm_postgis at cheapcomplexdevices.com
Wed Aug 31 00:32:55 PDT 2005
With psql 8.1beta1 I get a pretty cryptic error message "ERROR: bogus varno: 1"
occasionally when I try to mix postgis (GIST-based) conditions with normal
conditions.  The statements where this happen are totally reroducable.
Attached is an example of this happening.   I'd be happy to look further,
but I'm not really sure where to look myself; and I must apologize in advance
that I'll be traveling for a couple days so my response time for getting more
info may be slow.  I'm using the latest postgis and the
beta of 8.1 on ubuntu.  The previous postgis claims to have some support for
8.1 added; and quite a few statements seem to work fine.
Any thoughts where I should look next?
    Ron Mayer
==  Mising postgis conditions with non postgis conditions in the where
==  clause, yielding "ERROR: bogus varno: 1"
[12]ron2:/home/ramayer/data/logs% psql fli fli
Welcome to psql 8.1beta1, the PostgreSQL interactive terminal.
Type:  \copyright for distribution terms
        \h for help with SQL commands
        \? for help with psql commands
        \g or terminate with semicolon to execute query
        \q to quit
fli=# explain select * from rtgr.lines,userfeatures.area_features
        where rtgr.lines.the_geom && setSRID('BOX3D(-121.29 38.58, -121.29
38.58)'::BOX3D, -1 )
         and rtgr.lines.the_geom && userfeatures.area_features.the_geom
         and length(name)>0  and userfeatures.area_features.featureid in (8);
fli-# fli-# fli-# ERROR:  bogus varno: 1
==  Just the postgis conditions - doesn't trigger the bogus varno.
         and rtgr.lines.the_geom && userfeatures.area_features.the_geom;
fli-# fli-# QUERY PLAN
  Nested Loop  (cost=0.00..8.90 rows=1 width=277)
    ->  Index Scan using rtgr_lines__gist on lines  (cost=0.00..5.01 rows=1
width=101)
          Index Cond: (the_geom &&
'01030000000100000005000000C3F5285C8F525EC00AD7A3703D4A4340C3F5285C8F525EC00AD7A3703D4A4340C3F5285C8F525EC00AD7A3703D4A4340C3F5285C8F525EC00AD7A3703D4A4340C3F5285C8F525EC00AD7A3703D4A4340'::geometry)
          Filter: (the_geom &&
    ->  Index Scan using area_features__postgis on area_features
(cost=0.00..3.87 rows=1 width=176)
          Index Cond: ("outer".the_geom && area_features.the_geom)
          Filter: ("outer".the_geom && area_features.the_geom)
(7 rows)
fli=#
