[postgis-users] COPY too slow when geometry column is indexed
Paul Ramsey
pramsey at refractions.net
Fri Dec 2 14:05:52 PST 2005
I could be wrong, but that graph looks fairly linear, and the r-tree
picksplit algorithm is O(N) (better than the traditional r-tree O
(N^2) algorithm though slightly less balanced). COPY (as with
everything in pgsql) is done in a transactional context, but the
whole COPY is treated as one transaction, so you are incurring the
bare minimum transaction overhead.
It is good you are talking with pg-performance on WAL, since I have
little experience in write performance tuning. In general terms,
what is your system doing while this happens? CPU at 100%? IO? How
is it responding to load, where is there binding?
P
On 2-Dec-05, at 12:51 PM, Rick Schumeyer wrote:
> I attached a plot of the COPY times, showing how things slow down as
> more files are added. Each file contains over 200,000 records.
> I added a second drive to my system, and moved the WAL to the new
> drive,
> per a discussion on the pg-performance list. It helped a little,
> but not
> enough - see the attached plot.
> Here is the table structure:
> bed=# \d data
> Table "public.data"
> Column | Type | Modifiers
> rid | integer | not null
> range | real | not null
> x | real |
> y | real |
> z | real |
> bs | real |
> snr | real |
> rvel | real |
> cfar | smallint |
> geom | geometry |
> Indexes:
> "data_pkey" PRIMARY KEY, btree (rid, range)
> "data_rid_ix" btree (rid)
> "geom_index" gist (geom)
> Check constraints:
> "enforce_dims_geom" CHECK (ndims(geom) = 2)
> "enforce_geotype_geom" CHECK (geometrytype(geom) =
> 'POINT'::text OR geom
> IS NULL)
> "enforce_srid_geom" CHECK (srid(geom) = 2959)
> Foreign-key constraints:
> "data_rid_fkey" FOREIGN KEY (rid) REFERENCES record(rid)
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of strk at refractions.net
>> Sent: Friday, December 02, 2005 5:04 AM
>> To: 'PostGIS Users Discussion'
>> Subject: Re: [postgis-users] COPY too slow when geometry column is
>> indexed
>> On Fri, Dec 02, 2005 at 09:28:17AM -0000, Mark Cave-Ayland wrote:
>>> Hi Rick,
>>> In order to assist with something like this, we need more
>>> information
>> such
>>> as:
>>> - \dt output of the table you are inserting data into
>>> - Actual timings for each progressive insert
>>> - Number of records added during each insert
>> Also note he was talking about COPY, not insert.
>> Maybe transaction management does also influence
>> that, I suggest to perform the tests also with
>> small transactions.
>> --strk;
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> <copy.png>
