[postgis-users] problem compiling postgis 1.0.5 and 1.0.6
strk at refractions.net
Wed Dec 7 03:44:07 PST 2005
1: Upgraded postgresql from which version to which other version ?
2: Can you use postgresql w/out postgis ?
3: Can you find libpq.so* under your new postgresql source tree ?
4: Did you reconfigure postgis after postgresql upgrade (make clean) ?
--strk;
On Wed, Dec 07, 2005 at 12:43:42PM +0100, Guillaume Sueur wrote:
> I must say too that I make the installation yesterday on a new system
> and it went fine. Could the problem come from the upgrade of postgresql ?
> I did stop the postmaster, then make uninstall from the source tree, rm
> -rf on the /usr/local/pgsql directory
> and then build of the new postgresql. Did I do something wrong ?
> thanks
> strk at refractions.net a écrit :
> >On Wed, Dec 07, 2005 at 12:17:58PM +0100, Guillaume Sueur wrote:
> >>Hi,
> >>an old problem shows up again.
> >>I've upgraded from postgresql 8.0 to 8.1 and it went ok, the postmaster
> >>is running again.
> >>But when I try to compile postgis 1.0.6 or 1.0.5 from the contrib
> >>directory, I have the following message : usr/bin/ld: can't find -lpq
> >>I checked these points :
> >> - libpq.so is under /usr/local/pgsql/lib
> >> - /usr/local/pgsql/lib is in /etc/ld.so.conf
> >> - ldconfig has been run after that.
> >>and I still have the same problem.
> >>Any idea ?
> >The postgresql source must be configured and built.
> >Postgis 1.0.x still uses data in pgsql source tree.
> >--strk;
> > /"\ ASCII Ribbon Campaign
> > \ / Respect for low technology.
> > X Keep e-mail messages readable by any computer system.
> > / \ Keep it ASCII.
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
> Guillaume SUEUR
> GEOSIGNAL - Groupe BVA
> 25bis Avenue Marcel Dassault
> 31505 TOULOUSE CEDEX 5
/ \ Keep it ASCII.
