[postgis-users] problem compiling postgis 1.0.5 and 1.0.6
Guillaume Sueur guillaume.sueur at geosignal.fr
Wed Dec 7 04:10:33 PST 2005
strk at refractions.net a écrit :
> 1: Upgraded postgresql from which version to which other version ?
from 8.0RC1 to 8.1
> 2: Can you use postgresql w/out postgis ?
yes
> 3: Can you find libpq.so* under your new postgresql source tree ?
no
> 4: Did you reconfigure postgis after postgresql upgrade (make clean) ?
yes, I now use the new postgis 1.0.6
> --strk;
> On Wed, Dec 07, 2005 at 12:43:42PM +0100, Guillaume Sueur wrote:
>>I must say too that I make the installation yesterday on a new system
>>and it went fine. Could the problem come from the upgrade of postgresql ?
>>I did stop the postmaster, then make uninstall from the source tree, rm
>>-rf on the /usr/local/pgsql directory
>>and then build of the new postgresql. Did I do something wrong ?
>>thanks
>>>On Wed, Dec 07, 2005 at 12:17:58PM +0100, Guillaume Sueur wrote:
>>>>Hi,
>>>>an old problem shows up again.
>>>>I've upgraded from postgresql 8.0 to 8.1 and it went ok, the postmaster
>>>>is running again.
>>>>But when I try to compile postgis 1.0.6 or 1.0.5 from the contrib
>>>>directory, I have the following message : usr/bin/ld: can't find -lpq
>>>>I checked these points :
>>>>	- libpq.so is under /usr/local/pgsql/lib
>>>>	- /usr/local/pgsql/lib is in /etc/ld.so.conf
>>>>	- ldconfig has been run after that.
>>>>and I still have the same problem.
>>>>Any idea ?
>>>The postgresql source must be configured and built.
>>>Postgis 1.0.x still uses data in pgsql source tree.
>>>--strk;
>>>/"\    ASCII Ribbon Campaign
>>>\ /    Respect for low technology.
>>> X     Keep e-mail messages readable by any computer system.
>>>/ \    Keep it ASCII.
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>Guillaume SUEUR
>>GEOSIGNAL - Groupe BVA
>>25bis Avenue Marcel Dassault
>>31505 TOULOUSE CEDEX 5
Guillaume SUEUR
