[postgis-users] postgis install under suse 10.0
Poizot Emmanuel poizot at cnam.fr
Tue Dec 20 03:33:21 PST 2005
Poizot Emmanuel wrote:
> Hi,
> as I couldn't resolve my probs to instal postgis, I restart from the
> beginning :)
> I did uninstall everythink, i.e. proj, geos, readline, postgres, postgis.
> I did download the last tar.gz of all this previous packages and
> installed them one by one.
> proj -> ok, then
> readline -> ok, then
> I did at this point a ldconfig -> ok
> geos -> ok, then
> postgres -> can't find readline !!
> I did check in /usr/local/lib and found libreadline.*.* !
> To compile postgres I started with:
> LDFLAGS=-lsstdc++ ./configure --with-libs=/usr/local/lib
> --with_includes=/usr/local/include --enable-multibyte --with-CXX
> --prefix=/usr --sysconfdir=/etc
> I can't understand why it don't find readline.
> I know it's a postgres probs but  it's a way I must go through before
> installing postgis.
> Regards
> Emmanuel Poizot
> Cnam/Intechmer
> B.P. 324
> 50103 Cherbourg Cedex
> Phone (Direct) : (00 33)(0)233887342
> Fax : (00 33)(0)233887339
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
I resolved (apparently) by installing redaline-devel from rpm packages
and deleting "--with-libs=/usr/local/lib" from postgres configure line
script.
After all goes fine. I installed Postgis and now can create database and
add postgis support through the 2 sql command files.
Next step is to install qgis and have access to postgis layer through it :)
What a beautiful world....
Regards
Cordialement
Emmanuel Poizot
Cnam/Intechmer
B.P. 324
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051220/a42001e9/attachment.vcf>
