[postgis-users] Re: How to fix not valid polygons
Stephen Woodbridge woodbri at swoodbridge.com
Tue Dec 20 10:12:44 PST 2005
Amit Kulkarni wrote:
> I did it inside a traditional GIS and then dump/import to PostGIS.
> ArcGIS has a 'Explode Multi-part' feature. I wrote some VBA code, and
> exploded lines (trivial change for polygons I believe) were marked with
> a comment. I unfortunately don't have the code because the laptop
> crashed, a BSOD.
> But, the other developers may have a better solution.
Amit,
Thank you for the suggestion. I don't have ArcGIS and was hoping to do
this in postGIS.
List,
Is it possible to deconstruct geometry (polygons specifically) short of
hacking up the AsText() string representation of them?
-Steve
> Anyway, is this the best approach? Do you see problems with this
> approach? What are my other options? getting good polygons to start
> with does not appear to be an option at this point.
