[postgis-users] Converting WKT or WKB
Abe Gillespie agillesp at vt.edu
Sun Feb 6 11:17:54 PST 2005
Thanks for the help, but I intend to keep my PostGIS data in it's
native format.  Only at the instant I want to use the data inside
ESRI's API do I need to do the conversion.
I'm trying to create a tool that allows read / write ability of PostGIS
inside of ArcMap.  And yes I'm familiar with pgArc ... but it's
incomplete, slow, and buggy.
-Abe
On Feb 6, 2005, at 1:38 PM, Brent Wood wrote:
> --- Abe Gillespie <agillesp at vt.edu> wrote:
>> Hello all.  I'm new to the list.
>> I've just started using PostGIS, I'm one from the MapServer crowd.
>> I'd
>> like to use PostGIS with some ESRI technologies and am hoping to find
>> an easy way to go from PostGIS objects to ESRI objects.
> As you are using PostGIS I'm assuming that you are just interested in
> using
> vector data?
> There is a shp2pgsql program which turns a shpfile into a file of SQL
> commands
> to load into PostGIS. The QGIS package has a plugin which allows you
> to click
> on shapefiles and choose a PostGIS database to load them into. Also
> the ogr2ogr
> program (part of the GDAL suite) converts between various vector
> formats, and
> can convert to/from PostGIS tables, shape and Arc coverage (amongst
> others).
> Then there is avce00 which works with e00 Arc export files, converting
> then
> to/from coverages.
> So these are several Open Source packages which support shapefiles and
> PostGIS,
> as well as a way to turn e00 & coverages into shapefiles.
> The Postgres native spatial data types are not compatible AFAIK with
> PostGIS,
> nor are there any conversion tools. I think I have seen this issue
> raised
> before, so trawling the list archives might find you something.
> Note that the shapefile spec necessarily loses some topology info, etc
> from
> coverages, and that PostGIS does not really support topology, and only
> features
> defined by coordinate pairs, so circles etc cannot be represented by a
> point &
> radius, but must be renderedr into an arc of coords. Dynamic
> segmentation &
> other capabilities can sort of be implemented with suitable table
> structures,
> but depending on your Arc data you may lose something.
> I'm not expert in this area, but I believe geometries are stored as
> binary, but
> can be extracted as WKT if required.
> Brent Wood
>> My first idea is using Postgres native geometry types.  The .Net data
>> connector (Npgsql) has support for these built in types.  Are there
>> any
>> PostGIS functions that will convert its types to Postgres geometry
>> types?  I imagine things working sort of like:
>> string sql = "SELECT as_native_postgres_box(extent(the_geom)) FROM
>> shape_table";
>> NpgsqlCommand cmd = new NpgsqlCommand(sql, con);
>> NpgsqlBox box = (NpgsqlBox)cmd.ExecuteScalar();
>> The second idea is to just use a third party library to do the parsing
>> for me.  I see there's a java one, but I'm looking for a .Net happy
>> library.
>> Also, and this is OT from the subject, but how do you specify to
>> PostGIS whether the geometries are stored as WKT or WKB?  Mine are all
>> WKT and I'm curious in case down the road I want to use WKB.
>> Thanks for any help.
>> -Abe
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
