[postgis-users] Error when getting geometry as binary
Paul Ramsey
pramsey at refractions.net
Sun Feb 6 20:43:47 PST 2005
Well, I think it is still a valid bug, but you are trying to make WKB
out of a bbox (the return from extent) and there is no such thing as a
WKB bbox. So things should fail a little more gracefully. The
envelope() trick turns the bbox into a polygon, for which there is a
WKB form.
P.
On 6-Feb-05, at 7:09 PM, Abe Gillespie wrote:
> That succeeds fine. Know what the problem is then?
> -Abe
> On Feb 6, 2005, at 8:09 PM, Paul Ramsey wrote:
>> What happens if you do asbinary(envelope(extent(the_geom)))?
>> On 6-Feb-05, at 4:59 PM, Abe Gillespie wrote:
>>> This statement works fine:
>>> SELECT extent(the_geom) from shape_table
>>> But this statement:
>>> SELECT asBinary(extent(the_geom)) from shape_table
>>> results in:
>>> ERROR: invalid memory alloc request size 1074393504
>>> I'm running PostgreSQL 7.4.1 / PostGIS 0.9.1 on a Debian Linux
>>> install.
>>> Thanks.
>>> -Abe
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
