[postgis-users] bugs in postgis-1.0RC2 with postgres 7.2.1
Markus Schaber
schabios at logi-track.com
Tue Feb 8 04:49:22 PST 2005
Hi, Alex,
alex bodnaru schrieb:
> thanks for your prompt response.
> included is a file with my javac complains.
> tommorow i will investigate my precise environment.
Okay. I currently do not have a debian woody accessible, to test it
myself, but I think I can provide workarounds for most of those errors.
> Found 1 semantic error compiling "src/org/postgis/PGgeometry.java":
> 76. srid = Integer.parseInt(t.getToken(0).split("=")[1]);
> *** Error: No method named "split" was found in type "java/lang/String".
String.split() exists since JDK 1.4, but I can provide an utility
function for this or use StringTokenizer, as I do not really need the
Regex functionality.
> Found 2 semantic errors compiling "src/org/postgis/Point.java":
> 229. throw new AssertionError("Illegal dimension of Point" + this.dimension);
> *** Error: The type of the expression in this throw statement, "org/postgis/AssertionError", is not assignable to an exception in the throws clause of the enclosing method or constructor "double distance(org.postgis.Point other);"; nor is it a subclass of RuntimeException or Error.
The same for AssertionError (since 1.4), maybe IllegalArgumentException
is a good replacement for this.
> Found 1 semantic error compiling "src/examples/TestServer.java":
> 66. ((org.postgresql.PGConnection) conn).addDataType("geometry", "org.postgis.PGgeometry");
> *** Error: Type org/postgresql/PGConnection was not found.
I do not really know the cause of this error, it may be caused by the
errors above.
> Found 1 semantic error compiling "src/org/postgis/DriverWrapper.java":
> 72. super();
> *** Error: A constructor associated with this type, "DriverWrapper", does not throw the exception "java/sql/SQLException" thrown by its super type, "org/postgresql/Driver".
> make[1]: *** [compile] Error 1
> make[1]: Leaving directory `/common/src/postgis/postgis-cvs/jdbc2'
> make: *** [build-stamp] Error 2
The same here.
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050208/4ca4473d/attachment.pgp>
