[postgis-users] Fwd: [Gdal-dev] ogr2ogr, postgis, s57 & enforce_dims_wkb_geometry
Tore Halset halset at pvv.ntnu.no
Wed Feb 9 04:41:51 PST 2005
Hello.
I wonder if this is a problem with postgis and/or ogr2ogr. I have
reported the issue to gdal bugzilla
http://bugzilla.remotesensing.org/show_bug.cgi?id=768
Regards,
  - Tore.
Begin forwarded message:
> From: Frank Warmerdam <fwarmerdam at gmail.com>
> Date: February 8, 2005 20:19:02 CET
> To: Tore Halset <halset at pvv.ntnu.no>
> Cc: gdal-dev <gdal-dev at remotesensing.org>
> Subject: Re: [Gdal-dev] ogr2ogr, postgis, s57 &
> Reply-To: warmerdam at pobox.com
> On Tue, 8 Feb 2005 12:11:54 +0100, Tore Halset <halset at pvv.ntnu.no>
> wrote:
>> Hello.
>> I have installed the following on my mac with Mac OS X 10.3.7:
>> postgresql-8.0.1
>> postgis-1.0.0-rc2
>> gdal-1.2.5
>> I am trying to load a single S-57 cell into the database, but the
>> first
>> insert fails.
>> LOG:  statement: INSERT INTO "airare" (wkb_geometry , "rcid", "prim",
>> "grup", "objl", "rver", "agen", "fidn", "fids", "lnam", "catair",
>> "scamin") VALUES (GeometryFromText('POINT (15.47197780
>> 78.24509130)'::TEXT,1) , 684, 1, 2, 2, 1, 340, 1334049, 50002,
>> '015400145B21C352', '2', 270000)
>> ERROR:  new row for relation "airare" violates check constraint
>> "enforce_dims_wkb_geometry"
>> This is the same error with another cell:
>> LOG:  statement: INSERT INTO "achare" (wkb_geometry , "rcid", "prim",
>> "grup", "objl", "rver", "agen", "fidn", "fids", "lnam", "catach",
>> "status", "scamin") VALUES (GeometryFromText('POINT (16.82046390
>> 77.82454520)'::TEXT,1) , 476, 1, 2, 4, 1, 340, 953081, 50004,
>> '0154000E8AF9C354', '1', '3', 360000)
>> ERROR:  new row for relation "achare" violates check constraint
>> The enforce_dims_wkb_geometry constraint are equal in airare and
>> achare:
>>      "enforce_dims_wkb_geometry" CHECK (ndims(wkb_geometry) = 3)
>> Anyone knows how this can be fixed?
> Tore,
> As I read this, PostGIS is now requiring a 0.0 Z coordinate on the
> WKT for geometries inserted in a 3D geometry column.  Is that right?
> If so, this is quite annoying.  Currently the OGRGeometry class
> freely produces (x,y) style WKT if the Z coordinate is zero. In fact,
> internally it doesn't even carry around a dimension.  It just checks
> for non-zero Z values.  While this can be construed as a failure of
> OGR, I am not convinced that particularly tight rules were ever
> available for 3D geometries in the simple features model since the
> simple features model was originally 2D only.
> However, none of that necessarily matters to you.  You just want to
> load some data into PostGIS.  That temporary workaround is to
> dump your data to a shapefile with ogr2ogr and then use the PostGIS
> shapefile loader to load it.  However, as with the tiger->shapefile
> problem earlier today, you will find you need to use -skipfailures and
> will lose a few esoteric attributes if you go via shapefile.
> The long term solution may mean I need to really keep track of
> dimension in OGR or at least somehow hack the PostGIS driver
> to force geometries to match the dimension of the table.
> You might also find that you can reload the PostGIS SQL with
> this constraint removed.  I have had some success with this
> approach in the past.
> I would appreciate it if you could submit a bugzilla bug against
> OGR on this issue.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
