[postgis-users] Fwd: [Gdal-dev] ogr2ogr, postgis, s57 & enforce_dims_wkb_geometry
strk at refractions.net strk at refractions.net
Wed Feb 9 05:52:17 PST 2005
On Wed, Feb 09, 2005 at 01:41:51PM +0100, Tore Halset wrote:
> Hello.
> I wonder if this is a problem with postgis and/or ogr2ogr. I have
> reported the issue to gdal bugzilla
> http://bugzilla.remotesensing.org/show_bug.cgi?id=768
> Regards,
>  - Tore.
Frank explained the problem very well.
You can drop the dimensions constraint on your table if you don't
care about in-table dimension consistency:
ALTER TABLE airare DROP CONSTRAINT enforce_dims_wkb_geometry;
--strk;
> Begin forwarded message:
> >From: Frank Warmerdam <fwarmerdam at gmail.com>
> >Date: February 8, 2005 20:19:02 CET
> >To: Tore Halset <halset at pvv.ntnu.no>
> >Cc: gdal-dev <gdal-dev at remotesensing.org>
> >Subject: Re: [Gdal-dev] ogr2ogr, postgis, s57 &
> >Reply-To: warmerdam at pobox.com
> >On Tue, 8 Feb 2005 12:11:54 +0100, Tore Halset <halset at pvv.ntnu.no>
> >wrote:
> >>Hello.
> >>I have installed the following on my mac with Mac OS X 10.3.7:
> >>postgresql-8.0.1
> >>postgis-1.0.0-rc2
> >>gdal-1.2.5
> >>I am trying to load a single S-57 cell into the database, but the
> >>first
> >>insert fails.
> >>LOG:  statement: INSERT INTO "airare" (wkb_geometry , "rcid", "prim",
> >>"grup", "objl", "rver", "agen", "fidn", "fids", "lnam", "catair",
> >>"scamin") VALUES (GeometryFromText('POINT (15.47197780
> >>78.24509130)'::TEXT,1) , 684, 1, 2, 2, 1, 340, 1334049, 50002,
> >>'015400145B21C352', '2', 270000)
> >>ERROR:  new row for relation "airare" violates check constraint
> >>"enforce_dims_wkb_geometry"
> >>This is the same error with another cell:
> >>LOG:  statement: INSERT INTO "achare" (wkb_geometry , "rcid", "prim",
> >>"grup", "objl", "rver", "agen", "fidn", "fids", "lnam", "catach",
> >>"status", "scamin") VALUES (GeometryFromText('POINT (16.82046390
> >>77.82454520)'::TEXT,1) , 476, 1, 2, 4, 1, 340, 953081, 50004,
> >>'0154000E8AF9C354', '1', '3', 360000)
> >>ERROR:  new row for relation "achare" violates check constraint
> >>The enforce_dims_wkb_geometry constraint are equal in airare and
> >>achare:
> >>     "enforce_dims_wkb_geometry" CHECK (ndims(wkb_geometry) = 3)
> >>Anyone knows how this can be fixed?
> >Tore,
> >As I read this, PostGIS is now requiring a 0.0 Z coordinate on the
> >WKT for geometries inserted in a 3D geometry column.  Is that right?
> >If so, this is quite annoying.  Currently the OGRGeometry class
> >freely produces (x,y) style WKT if the Z coordinate is zero. In fact,
> >internally it doesn't even carry around a dimension.  It just checks
> >for non-zero Z values.  While this can be construed as a failure of
> >OGR, I am not convinced that particularly tight rules were ever
> >available for 3D geometries in the simple features model since the
> >simple features model was originally 2D only.
> >However, none of that necessarily matters to you.  You just want to
> >load some data into PostGIS.  That temporary workaround is to
> >dump your data to a shapefile with ogr2ogr and then use the PostGIS
> >shapefile loader to load it.  However, as with the tiger->shapefile
> >problem earlier today, you will find you need to use -skipfailures and
> >will lose a few esoteric attributes if you go via shapefile.
> >The long term solution may mean I need to really keep track of
> >dimension in OGR or at least somehow hack the PostGIS driver
> >to force geometries to match the dimension of the table.
> >You might also find that you can reload the PostGIS SQL with
> >this constraint removed.  I have had some success with this
> >approach in the past.
> >I would appreciate it if you could submit a bugzilla bug against
> >OGR on this issue.
> >Best regards,
> >I set the clouds in motion - turn up   | Frank Warmerdam,
> >light and sound - activate the windows | http://pobox.com/~warmerdam
> >and watch the world go round - Rush    | Geospatial Programmer for Rent
> postgis-users mailing list
