[postgis-users] ole db, arccatalog and arcmap
Craig Miller craig.miller at spatialminds.com
Fri Feb 11 08:27:29 PST 2005
That data provider doesn't support the OGIS extensions to OLEDB.
Are you looking to view tables, or feature tables?  If it is the latter then
it won't work.  If it is the former, in theory it should work.
--Craig
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ieuan
Williams
Sent: Friday, February 11, 2005 3:21 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ole db, arccatalog and arcmap
Has anybody managed to connect to a postgresql/postgis db from arcmap.
I've set up an ole db data link (using 1.0.0.15) in arccatalog to a
postrgesql 8/postgis (on win2k), the test connection comes back as
successful, but when I try to use this connection in arcmap no tables
from the database are shown. Has anybody got any ideas?
Thanks
Ieuan
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
