[postgis-users] transform function
strk at refractions.net
Sat Feb 12 04:26:42 PST 2005
On Fri, Feb 11, 2005 at 12:47:56PM -0500, Jean-Denis Giguere wrote:
> Greetings,
> I would like to reproject data obtained with ogr2ogr. Sadly, I get all
> result with an empty geometry description.
> ogr2ogr generate spatial_ref_sys entry with the following fields : oid,
> srid and srtext (not proj4text).
> If I change the srid to a value generated by spatial_ref_sys.sql,
> everything works well. Do we need the proj4text column in
> spatial_ref_sys to use transform function ?
Yes, you do.
--strk;
> Jean-Denis
> Jean-Denis Giguère
> Étudiant en géomatique
> appliquée à l'environnement
> Stagiaire à l'Agence de développement
> de réseaux locaux de services de santé
> et de services sociaux de l'Estrie
> Tél. 829-3400 42008
> Courriel. jdenisgiguere at fastmail.fm
> postgis-users mailing list
