[postgis-users] Does PostGIS 1.0RC1/2 work with MS4W/Mapserver4.4.1?
Mike Leahy
mgleahy at fes.uwaterloo.ca
Mon Feb 14 06:42:32 PST 2005
No, I didn't...so I just tried the style you suggested, and no change in
results. The legend displays the layer name and the appropriate symbol...it's
just the points in the map that don't seem to get drawn...
Quoting TECHER Jean David <davidtecher at yahoo.fr>:
> Hi
> Did U try to change the size of the points U want to draw with
> mapserver...something like
> TYPE POINT
> CLASS
> STYLE
> COLOR 175 0 0
> SYMBOL "star"
> SIZE 7
> END----------------------------------------------------------------
> TECHER Jean David
> Responsable Informatique 01MAP
> e-mail: davidtecher at yahoo.fr
> Bureau: 04 67 45 60 27
> Portable: 06 85 37 36 75
> site perso : http://techer.pascal.free.fr/postgis/
> site pro: http://www.01map.com/download/
> K-S:"The greatest trick the devil pulled off was convincing people he didn't
> exist"
> ----- Original Message -----
> From: "Mike Leahy" <mgleahy at fes.uwaterloo.ca>
> To: <postgis-users at postgis.refractions.net>
> Sent: Monday, February 14, 2005 3:28 PM
> Subject: [postgis-users] Does PostGIS 1.0RC1/2 work with
> > Hello list,
> > I'm just wondering if anyone has been able to get Mapserver to draw maps
> with
> > PostGIS layers using the latest MS4W package with 1.0 RC1 or RC2 of
> PostGIS.
> > I'm having a bit of trouble...after updating PostGIS to the lastest
> version
> > available (via the windows installer), it seems that my
> Mapserver/Chameleon
> > application in my MS4W installation no longer likes PostGIS layers. I
> have a
> > fairly simple table in PostGIS with POINT geometry that I imported using
> > shp2pgsql (the version supplied with the installer). As far as I can
> tell, all
> > the data are valid...and Mapserver doesn't actually complain, it just
> draws a
> > blank layer instead of the points in the actual table. The same identical
> table
> > imported into PostGIS 0.9.1 had no troubles with my MS4W application...I
> can
> > only guess where I've gone wrong. Just to be sure, I set the extent in
> my
> > mapfile to the extents returned for the table from PostGIS, and the map
> still
> > appeared blank.
> > Can anyone recommend where I should look first to figure this out?
> > Thanks,
> > Mike
> > This mail sent through www.mywaterloo.ca
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
