[postgis-users] Does PostGIS 1.0RC1/2 work with MS4W/Mapserver 4.4.1?
Pericles S. Nacionales nacional at cbs.umn.edu
Mon Feb 14 08:37:07 PST 2005
Check http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1216.  This might be
the same issue you've run into.  If so, roll back to PostGIS 0.9.1.
-Perry
On Monday 14 February 2005 08:28 am, Mike Leahy wrote:
> Hello list,
> I'm just wondering if anyone has been able to get Mapserver to draw maps
> with PostGIS layers using the latest MS4W package with 1.0 RC1 or RC2 of
> PostGIS. I'm having a bit of trouble...after updating PostGIS to the
> lastest version available (via the windows installer), it seems that my
> Mapserver/Chameleon application in my MS4W installation no longer likes
> PostGIS layers.  I have a fairly simple table in PostGIS with POINT
> geometry that I imported using shp2pgsql (the version supplied with the
> installer).  As far as I can tell, all the data are valid...and Mapserver
> doesn't actually complain, it just draws a blank layer instead of the
> points in the actual table.  The same identical table imported into PostGIS
> 0.9.1 had no troubles with my MS4W application...I can only guess where
> I've gone wrong.    Just to be sure, I set the extent in my mapfile to the
> extents returned for the table from PostGIS, and the map still appeared
> blank.
> Can anyone recommend where I should look first to figure this out?
> Thanks,
> Mike
> This mail sent through www.mywaterloo.ca
> postgis-users mailing list
Dept. of Ecology, Evolution, and Behavior
University of Minnesota
work: 612 624 6713
e-mail: nacional at cbs.umn.edu
