[postgis-users] Does PostGIS 1.0RC1/2 work with MS4W/Mapserver 4.4.1?
Dirk Jesko
jesko at geocontent.de
Mon Feb 14 09:04:51 PST 2005
I am pretty sure that is the same issue. Until now I tested several
installation with always the same result: No mapserver will display
points coming from a PostGIS 1.0.0RC1 or newer.
I would really be interested whether this is caused by Mapserver or
PostGIS. Since the 0.9.x work and there are also no problems with other
geometry types like polygon or line, I doubt that the problem is caused
by the mapserver.
Regards,
Dirk
>Check http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1216. This might be
>the same issue you've run into. If so, roll back to PostGIS 0.9.1.
>-Perry
>On Monday 14 February 2005 08:28 am, Mike Leahy wrote:
>>Hello list,
>>I'm just wondering if anyone has been able to get Mapserver to draw maps
>>with PostGIS layers using the latest MS4W package with 1.0 RC1 or RC2 of
>>PostGIS. I'm having a bit of trouble...after updating PostGIS to the
>>lastest version available (via the windows installer), it seems that my
>>Mapserver/Chameleon application in my MS4W installation no longer likes
>>PostGIS layers. I have a fairly simple table in PostGIS with POINT
>>geometry that I imported using shp2pgsql (the version supplied with the
>>installer). As far as I can tell, all the data are valid...and Mapserver
>>doesn't actually complain, it just draws a blank layer instead of the
>>points in the actual table. The same identical table imported into PostGIS
>>0.9.1 had no troubles with my MS4W application...I can only guess where
>>I've gone wrong. Just to be sure, I set the extent in my mapfile to the
>>extents returned for the table from PostGIS, and the map still appeared
>>blank.
>>Can anyone recommend where I should look first to figure this out?
>>Thanks,
>>Mike
