[postgis-users] View area
strk at refractions.net
Wed Feb 16 09:06:30 PST 2005
On Wed, Feb 16, 2005 at 10:00:45AM -0700, Sean M. Montague wrote:
> I found a web site that said the version shipped with postgreSQL 8.0
> installer had problems and linked to a windows installer for PostGIS
> 0.9.1. So I reloaded it, which is the version below. I did get an
> improvement, I think, but still have problems with intersection. I
> actually got polygons, but they don't resemble what actually exists.
> Looks like they've been generalized into triangles, and some points were
> still returned.
> POSTGIS="0.9.1" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.0.1" RELPROC="0.0.1"
Are you input geometries valid - check isvalid() ?
Can you reproduce the *bug* with a single, full contained
( and possibly small ) sql script so I can take a look at it ?
--strk;
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Wednesday, February 16, 2005 1:23 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] View area
> On Tue, Feb 15, 2005 at 01:42:35PM -0700, Sean M. Montague wrote:
> > I'm using postgreSQL 8.0.1 win32 version and whichever postGIS comes
> > with it, 0.9.1 I think. My input geometries are multi-part polygons
> > imported from a shape file. Every state is its own multi-part poly,
> > regardless of the number of individual polys, at least as a shape
> file,
> > not sure how postGIS handles this. I'm also not sure what GEOS I'm
> > using. Is this an add-on installed separately?
> If intersection is working it's probably installed by the package
> you got. Check output of SELECT postgis_full_version() to find
> out the version.
> --strk;
> > --Sean
> > Sent: Tuesday, February 15, 2005 1:33 PM
> > On Tue, Feb 15, 2005 at 12:37:25PM -0700, Sean M. Montague wrote:
> > > I've investigated what the relationship of the points is to the
> > original
> > > poly layer, and they are not the vertices, at least not all of them.
> > > The original layer is the coast of south east Alaska with about 25
> > > islands. The points may be some of the vertices perhaps, they do
> lie
> > on
> > > the coasts. The summary() returns 556 "Object 0 is a POINT()" and 1
> > > "Object 0 is a LINESTRING() with 2 points". The up side is, they at
> > > least lie within my bounding box.
> > It sounds as a bug to me. Which GEOS version are you using ?
> > What types are input geometries ?
> > Which postgis version ? postgresql ?
> > --strk;
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
