[postgis-users] postgresql8.0 and postgis1.0.0
strk at refractions.net
Thu Feb 17 00:26:40 PST 2005
On Wed, Feb 16, 2005 at 06:16:36PM -0700, Pritesh Shah wrote:
> hi,
> I would like to thank everybody for their responses to my question. I
> tried a couple of things and the best thing for me was to use
> utils/postgis_restore.pl script.
> I ran this script on some sample databases and they all seemed to
> work, but partially, as there are still some errors.
> These errors are because some postgis content is not being stripped
> out while writing into the $dump.list file. A sample of where it fails
> is:
> CREATE FUNCTION wkb_recv(internal) RETURNS wkb
> AS '$libdir/libpostgis.so.0.8', 'WKB_recv'
> LANGUAGE c STRICT;
> ERROR: could not access file "$libdir/libpostgis.so.0.8": No such file or direc
> tory
> ALTER FUNCTION public.wkb_recv(internal) OWNER TO brook;
> ERROR: function public.wkb_recv(internal) does not exist
> This line should be stripped out as in the new postgis (1.0.0) there
> is nothing called "WKB_recv" which existed in the older version
> (0.8.2)
> There are many such cases where the postgis_restore.pl script fails in
> removing the postgis stuff. I'm currently working on getting this
> fixed.
I've added wkb_recv and wkb_send in the list of obsoleted functions
handled by postgis_restore.pl. Could you try current (CVS) version ?
Would you send a list of other uncought obsoleted functions ?
Be aware (if you're going to patch postgis_restore.pl yourself) that
some failures are due to different output from different versions
of pg_restore.
Note finally that the errors you're getting won't hurt unless the
restore call is interrupted by the error (ie. transactional).
--strk;
> Cheers,
> Pritesh
> On Wed, Feb 16, 2005 at 02:09:11AM -0700, Pritesh Shah wrote:
> > hi,
> > I'm trying to backup a server and restore it on a different machine
> > with newer versions of postgresql and postgis. Dumps have been created
> > for the following versions from the old database server:
> > Postgresql 7.4.6
> > Postgis 0.8.2
> > Now since both the packages have released newer versions i've
> > installed the following on my newer machine where i would like to
> > restore the dumped databases.
> > Postgresql 8.0.1 and
> > Postgis 1.0.0
> > For restoring the information i'm using
> > psql -e -f abc.sql template1
> > While restoring the dumps i've collected the following information
> > where the problem occurs:
> > CREATE FUNCTION histogram2d_in(cstring) RETURNS histogram2d
> > AS '$libdir/libpostgis.so.0.8', 'histogram2d_in'
> > LANGUAGE c STRICT;
> > psql:abc.sql:3947: ERROR: could not access file
> > "$libdir/libpostgis.so.0.8": No such file or directory
> > I understand that this is due to the following:
> > libpostgis.so.8.0 is now liblwgeom.so.1.0 and also
> > histogram2d_in is now lwhistogram2d_in
> > histogram2d_out is now lwhistogram2d_out and so on.
> > Now my problem is there are a lot of databases that use the postgis
> > stuff (like the histogram2d_in) which has changed from the older
> > version to the newer version. What do i do to overcome this problem??
> > Can somebody help me out with this??
> > Cheers,
> > Pritesh
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
