[postgis-users] Using exteriorring
Benoit Ogier
benoit.ogier at cbconseil.com
Fri Feb 18 09:03:22 PST 2005
i tried 2 geometry columns types
the input geometry column is from MULTIPOLYGON type
the output geometry column is from POLYGON type
I tried also with an output column of MULTIPOLYGON type, and with
request like :
update nt_ownership_ew set the_geom = exteriorring(the_geom)
Each time, i got an error like :
ERROR: new row for relation "nt_ownership_ew" violates check constraint
"enforce_geotype_the_geom"
I use PostGIS 0.9.0 with GEOS 2.0.0 and Proj 4.4.8 under PostGres
8.0.0beta1. My OS : Mac OS X 10.3.7.
Thanks,
BO
Le 18 févr. 05, à 17:27, strk at refractions.net a écrit :
> On Fri, Feb 18, 2005 at 05:04:19PM +0100, Benoit Ogier wrote:
>> Hi,
>> I would use the exteriorring function to get the exterior ring of
>> multi
>> polygons, convert them to a single poly and store result in a new
>> field
>> of my table "poly_test".
>> using this sql command :
>> update nt_ownership_ew SET the_geom2 = exteriorring(the_geom)
>> I get :
>> ERROR: new row for relation "poly_test" violates check constraint "en
>> force_geotype_the_geom2"
>> the_geom is MULTIPOLYGON kind,
>> the_geom2 is POLYGON kind,
>> Questions :
>> - Is it the recommanded way to convert multi-polys to single polys ?
>> - If yes, where is the error ?
> You did everything the way you should, just a question, which
> geometry type did you specify in the AddGeometryColumn() call
> to create the poly_test field ?
> --strk;
>> Thanks,
>> BO
>> Benoît Ogier{
>> Carte Blanche Conseil
>> 47, rue de Lancry
>> 75010 Paris
>> Tel : +33 1 42 41 21 21
>> Fax : +33 1 42 41 70 40
>> email : benoit.ogier at cbconseil.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Benoît Ogier{
47, rue de Lancry
75010 Paris
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050218/d9961a78/attachment.bin>
