[postgis-users] Using exteriorring
strk at refractions.net
Fri Feb 18 09:09:44 PST 2005
On Fri, Feb 18, 2005 at 06:03:22PM +0100, Benoit Ogier wrote:
> i tried 2 geometry columns types
> the input geometry column is from MULTIPOLYGON type
> the output geometry column is from POLYGON type
> I tried also with an output column of MULTIPOLYGON type, and with
> request like :
> update nt_ownership_ew set the_geom = exteriorring(the_geom)
> Each time, i got an error like :
> ERROR: new row for relation "nt_ownership_ew" violates check constraint "enforce_geotype_the_geom"
ExteriorRing() returns a LINESTRING, as per OGC specifications.
Output column should be LINESTRING.
I'm sorry I forgot that, so you need another function to store
it as a polygon...
With postgis-1.0 you can use MakePolygon(ExteriorRing(...)).
With postgis-0.x I'm afraid you have no easy way (but other
users might give you better suggestions)
--strk;
> I use PostGIS 0.9.0 with GEOS 2.0.0 and Proj 4.4.8 under PostGres
> 8.0.0beta1. My OS : Mac OS X 10.3.7.
> Thanks,
> BO
> Le 18 févr. 05, à 17:27, strk at refractions.net a écrit :
> > On Fri, Feb 18, 2005 at 05:04:19PM +0100, Benoit Ogier wrote:
> > > Hi,
> > > I would use the exteriorring function to get the exterior ring of
> > > multi
> > > polygons, convert them to a single poly and store result in a new
> > > field
> > > of my table "poly_test".
> > > using this sql command :
> > > update nt_ownership_ew SET the_geom2 = exteriorring(the_geom)
> > > I get :
> > > ERROR: new row for relation "poly_test" violates check constraint "enforce_geotype_the_geom2"
> > > the_geom is MULTIPOLYGON kind,
> > > the_geom2 is POLYGON kind,
> > > Questions :
> > > - Is it the recommanded way to convert multi-polys to single
> > > polys ?
> > > - If yes, where is the error ?
> > You did everything the way you should, just a question, which
> > geometry type did you specify in the AddGeometryColumn() call
> > to create the poly_test field ?
> > --strk;
> > > Thanks,
> > > BO
> > > Benoît Ogier{
> > > Carte Blanche Conseil
> > > 47, rue de Lancry
> > > 75010 Paris
> > > Tel : +33 1 42 41 21 21
> > > Fax : +33 1 42 41 70 40
> > > email : benoit.ogier at cbconseil.com
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Benoît Ogier{
> 47, rue de Lancry
> 75010 Paris
