[postgis-users] GeometryCollection vs LineString speed
strk at refractions.net strk at refractions.net
Wed Feb 23 01:05:38 PST 2005
What postgis version ?
--strk;
On Wed, Feb 23, 2005 at 01:08:46AM -0800, Ron Mayer wrote:
> Should I expect "&&" to be much faster on GeometryCollections
> than on LineStrings?
> I have two tables that differ only in whether the geometry is a
> linestring or a geometrycollection [\d tables shown below].
> Both have an index on the geometry column.
> Both are clustered on the geometry column.
> When I do queries, I was somewhat surprised to find the one with
> GEOMETRYCOLLECTION to be about twice as fast as LINESTRING.
>     TIME     | what..
>   3.71 sec   | seq scan using LINESTRING
>   1.51 sec   | seq scan using GEOMETRYCOLLECTION
>     .59 sec  | index scan using LINESTRING
>     .37 sec  | index scan using GEOMETRYCOLLECTION
> Does this suggest that I should be using GEOMETRYCOLLECTION for
> roads on big maps?  Or that I add another column for the box3d
> itself?
> Explain analyze output and table definitions shown below...
>     Thanks,
>     Ron
> fli=# explain analyze SELECT 1 from rtgr.lines WHERE the_geom &&
> setSRID('BOX3D(-84.45189 30.3162978571429,-84.10464
> 30.5544121428571)'::BOX3D, find_srid('','rtgr.line$
>                                       QUERY PLAN                          $
>  Index Scan using rtgr_lines__gist on lines  (cost=0.00..23124.39
> rows=7146 width=0) (actual time=0.096..554.138 rows=17997 loops=1)
>    Index Cond: (the_geom &&
> '01030000000100000005000000EDD808C4EB1C55C0403978E5F8503E40EDD808C4EB1C55C0971346F4ED8D3E409F76F86BB20655C0971346F4ED8D3E409F76F86BB20655C0$
>  Total runtime: 593.868 ms
> (3 rows)
> fli=# explain analyze SELECT 1 from rtgr.lines2 WHERE the_geom &&
> 30.5544121428571)'::BOX3D, find_srid('','rtgr.lin$
>                                       QUERY PLAN                          $
>  Index Scan using rtgr_lines2__gist on lines2  (cost=0.00..25437.85
> rows=7615 width=0) (actual time=0.073..337.110 rows=17997 loops=1)
>  Total runtime: 375.467 ms
> (3 rows)
> fli=# set enable_indexscan=false;
> SET
> 30.5544121428571)'::BOX3D, find_srid('','rtgr.lines','the_geom') );
>                                     QUERY PLAN
>  Seq Scan on lines  (cost=0.00..8543.50 rows=2 width=0) (actual
> time=0.051..3682.902 rows=17997 loops=1)
>    Filter: (the_geom &&
> '01030000000100000005000000EDD808C4EB1C55C0403978E5F8503E40EDD808C4EB1C55C0971346F4ED8D3E409F76F86BB20655C0971346F4ED8D3E409F76F86BB20655C0403978E5F8503E40EDD808C4EB1C55C0403978E5F8503E40'::geometry)
>  Total runtime: 3714.877 ms
> (3 rows)
> 30.5544121428571)'::BOX3D, find_srid('','rtgr.lines2','the_geom') );
>                                     QUERY PLAN
>  Seq Scan on lines2  (cost=0.00..9304.46 rows=7676 width=0) (actual
> time=0.268..1562.084 rows=17997 loops=1)
>  Total runtime: 1587.488 ms
> (3 rows)
> fli=# \d rtgr.lines;
>               Table "rtgr.lines"
>   Column   |         Type         | Modifiers
>  tigerfile | integer              |
>  tlid      | integer              |
>  cfcc      | character varying(3) |
>  name      | text                 |
>  the_geom  | geometry             | not null
> Indexes:
>     "lines__tlid" btree (tlid)
>     "rtgr_lines2__name" btree (name)
>     "rtgr_lines__gist" gist (the_geom) CLUSTER
> Check constraints:
>     "enforce_srid_the_geom" CHECK (srid(the_geom) = -1)
>     "enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
>     "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
> 'LINESTRING'::text OR the_geom IS NULL)
> fli=# \d rtgr.lines2
>              Table "rtgr.lines2"
>  tlid      | integer              |
>  name      | text                 |
> Indexes:
>     "rtgr_lines2__gist" gist (the_geom) CLUSTER
> Check constraints:
> 'GEOMETRYCOLLECTION'::text OR the_geom IS NULL)
> fli=#
> fli=# select relname,reltuples,relpages from pg_class where relname like
> 'lines%';
>    relname   | reltuples | relpages
>  lines       |    305640 |     4708
>  lines2      |    305640 |     5467
> (2 rows)
> fli=#
> postgis-users mailing list
