[postgis-users] GeometryCollection vs LineString speed
Ron Mayer
rm_postgis at cheapcomplexdevices.com
Wed Feb 23 01:08:46 PST 2005
Should I expect "&&" to be much faster on GeometryCollections
than on LineStrings?
I have two tables that differ only in whether the geometry is a
linestring or a geometrycollection [\d tables shown below].
Both have an index on the geometry column.
Both are clustered on the geometry column.
When I do queries, I was somewhat surprised to find the one with
GEOMETRYCOLLECTION to be about twice as fast as LINESTRING.
TIME | what..
3.71 sec | seq scan using LINESTRING
1.51 sec | seq scan using GEOMETRYCOLLECTION
.59 sec | index scan using LINESTRING
.37 sec | index scan using GEOMETRYCOLLECTION
Does this suggest that I should be using GEOMETRYCOLLECTION for
roads on big maps? Or that I add another column for the box3d
itself?
Explain analyze output and table definitions shown below...
Thanks,
Ron
fli=# explain analyze SELECT 1 from rtgr.lines WHERE the_geom &&
setSRID('BOX3D(-84.45189 30.3162978571429,-84.10464
30.5544121428571)'::BOX3D, find_srid('','rtgr.line$
QUERY PLAN $
Index Scan using rtgr_lines__gist on lines (cost=0.00..23124.39
rows=7146 width=0) (actual time=0.096..554.138 rows=17997 loops=1)
Index Cond: (the_geom &&
'01030000000100000005000000EDD808C4EB1C55C0403978E5F8503E40EDD808C4EB1C55C0971346F4ED8D3E409F76F86BB20655C0971346F4ED8D3E409F76F86BB20655C0$
Total runtime: 593.868 ms
(3 rows)
fli=# explain analyze SELECT 1 from rtgr.lines2 WHERE the_geom &&
30.5544121428571)'::BOX3D, find_srid('','rtgr.lin$
QUERY PLAN $
Index Scan using rtgr_lines2__gist on lines2 (cost=0.00..25437.85
rows=7615 width=0) (actual time=0.073..337.110 rows=17997 loops=1)
Total runtime: 375.467 ms
(3 rows)
fli=# set enable_indexscan=false;
SET
30.5544121428571)'::BOX3D, find_srid('','rtgr.lines','the_geom') );
QUERY PLAN
Seq Scan on lines (cost=0.00..8543.50 rows=2 width=0) (actual
time=0.051..3682.902 rows=17997 loops=1)
Filter: (the_geom &&
'01030000000100000005000000EDD808C4EB1C55C0403978E5F8503E40EDD808C4EB1C55C0971346F4ED8D3E409F76F86BB20655C0971346F4ED8D3E409F76F86BB20655C0403978E5F8503E40EDD808C4EB1C55C0403978E5F8503E40'::geometry)
Total runtime: 3714.877 ms
(3 rows)
30.5544121428571)'::BOX3D, find_srid('','rtgr.lines2','the_geom') );
QUERY PLAN
Seq Scan on lines2 (cost=0.00..9304.46 rows=7676 width=0) (actual
time=0.268..1562.084 rows=17997 loops=1)
Total runtime: 1587.488 ms
(3 rows)
fli=# \d rtgr.lines;
Table "rtgr.lines"
Column | Type | Modifiers
tigerfile | integer |
tlid | integer |
cfcc | character varying(3) |
name | text |
the_geom | geometry | not null
Indexes:
"lines__tlid" btree (tlid)
"rtgr_lines2__name" btree (name)
"rtgr_lines__gist" gist (the_geom) CLUSTER
Check constraints:
"enforce_srid_the_geom" CHECK (srid(the_geom) = -1)
"enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
"enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
'LINESTRING'::text OR the_geom IS NULL)
fli=# \d rtgr.lines2
Table "rtgr.lines2"
tlid | integer |
name | text |
Indexes:
"rtgr_lines2__gist" gist (the_geom) CLUSTER
Check constraints:
'GEOMETRYCOLLECTION'::text OR the_geom IS NULL)
fli=#
fli=# select relname,reltuples,relpages from pg_class where relname like
'lines%';
relname | reltuples | relpages
lines | 305640 | 4708
lines2 | 305640 | 5467
(2 rows)
fli=#
