[postgis-users] Installing postgis-0.9.1
Shaq Gbadebo
s_gbadebo at hotmail.com
Thu Feb 24 03:18:58 PST 2005
I forgot to mention, I can find where the /pg_config, should be pointing to
on the machine usr/local/pgsql/lib, this directory has libpostgis file. But
the command does not work.
>From: Markus Schaber <schabios at logi-track.com>
>Reply-To: PostGIS Users Discussion
<postgis-users at postgis.refractions.net>
>Subject: Re: [postgis-users] Installing postgis-0.9.1
>Date: Thu, 24 Feb 2005 11:40:52 +0100
>Hi, Shaq,
>Shaq Gbadebo schrieb:
> > Thank you for your reply, Marcus!
> > The pg_config command did not work, so I gues there is something
wrong
> > with my postgresql installation, do you suggest I re-install the
> > database? If so, what do you think I might have done wrong in the
first
> > installation.
>What was the exact error message of pg_config?
>Did you install postgresql by source or via package management?
>Markus
>markus schaber | dipl. informatiker
>logi-track ag | rennweg 14-16 | ch 8001 zürich
>phone +41-43-888 62 52 | fax +41-43-888 62 53
>mailto:schabios at logi-track.com | www.logi-track.com
><< signature.asc >>
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
