[postgis-users] Installing postgis-0.9.1
Gerry Creager N5JXS
gerry.creager at tamu.edu
Thu Feb 24 07:38:03 PST 2005
"rpm -qa|grep postgres" will show what rpms are installed, then do an
"rpm -e {the names of the various appropriate packages to delete}"
gerry
Shaq Gbadebo wrote:
> Thanks again for your reply, Markus!
> Here is the exact error message.
> bash: pg_config: command not found
> I installed Postgresql-8.0.1, from source.
> But I have just realised that the postgresql-7.3, which came with redhat
> is still on the machine, and might be conflicting the newly installed
> database. Is there a way of getting rid of this version. Your help is
> highly appreciated.
> postgis-users mailing list
