[postgis-users] Installing postgis-0.9.1
Markus Schaber schabios at logi-track.com
Thu Feb 24 03:54:32 PST 2005
Hi, Shaq,
Shaq Gbadebo schrieb:
> Here is the exact error message.
> bash: pg_config: command not found
This indicates that either pg_config is not installed, or that it is not
in your path.
> I installed Postgresql-8.0.1, from source.
> But I have just realised that the postgresql-7.3, which came with redhat
> is still on the machine, and might be conflicting the newly installed
> database. Is there a way of getting rid of this version. Your help is
> highly appreciated.
To get rid of 7.3, you have to use your package manager, rpm on redhat.
I do not know how to do this on redhat, as I use debian which use
dpkg/apt as package management.
However, using package management and compiling PostgreSQL itsself are
not really on-topic here, so you may get better help on appropriate
lists where the experts lurk around.
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
